MAF scaling or injector scaling/latency
I've tried several different filters and the one that gave me the best result is the Vibrant filter with the internal cone and external filter areas. The MAF readings are as good as they were when they were stock.
Adding the heat shield also helped as well.
Since the days are getting colder your LTFTs will be affected. If the car is still running well then I would wait for warmer weather and then retune if necessary.
I just keep going back to an old thread I saw where nj2166 kept having issues with LTFT affecting his afr even when he was on stock airbox with drop in. He fixed his issue through rescaling his stock injectors. He suggested using latency to correct also. Adding latency to make to make the car richer during closed loop so that ltft decrease and have less effect on wot. Another suggestion is rescaling maf but I am
hesitant after reading this thread
EvoM Community Team
If your LTFT affecting your WOT tune is your only issue you should lower your mid -> high transition points. There have been a couple of threads on this recently.
It looks like you could lower your scaling by ~9% and just be fine (for now, until the weather changes), but I suspect thats not all there is to it (since you have messed with your MAF settings).
I haven't scaled maf yet, was debating on doing that or latency to fix LTFT. I like that hz idea but kind of want more testing before going that route. I mean isn't there a reason car came from factory with the hz crossover set? Ugh just don't know the right answer. If I adjust injector scaling or latency I have to readjust when te weather changes again?
But since we already monitor things like AFR with a wideband and want more consistent AFR from pull to pull, I think changing the crossover point to a lower number makes a ton of sense.
RS200Z
Sep 13, 2017 05:53 PM
Raceghost
Jun 1, 2016 12:30 AM
Ian0611
Oct 20, 2010 09:44 AM
PDXEvo
Aug 11, 2005 10:43 AM
