fat chick problem/ECU flash
I seached . I F ed up and let a fat chick tuch my lap top . I am computrer dum but learning .I was tring to figure out how to cut and past new info int ecu flash to convert over to speed/density. Some how all files are read as xml but i belive they should be BIN like they are on my PC .My lap top is in xml when looking in the same location as my pc. ECU flash says rom image is not readable ECU flash no longer links to car and can not read my saved files I have uninstalled and reinstalled ECU flash it did nothing to help .All I have learned Is never let a fat chick that says she knows what a xml file is touch your junk She said to cut and past it to note book make the change then I can put it back in ecu flash I now know that was bs . hope some one can help. And to top it off I have to smog this month
i seached . I f ed up and let a fat chick tuch my lap top . I am computrer dum but learning .i was tring to figure out how to cut and past new info int ecu flash to convert over to speed/density. Some how all files are read as xml but i belive they should be bin like they are on my pc .my lap top is in xml when looking in the same location as my pc. Ecu flash says rom image is not readable ecu flash no longer links to car and can not read my saved files i have uninstalled and reinstalled ecu flash it did nothing to help .all i have learned is never let a fat chick that says she knows what a xml file is touch your junk she said to cut and past it to note book make the change then i can put it back in ecu flash i now know that was bs . hope some one can help. And to top it off i have to smog this month
