How To: Speed Density on the evo8 using tephra v7/Phenem pre-patched roms
Old Jan 18, 2014 | 03:44 PM
  #271
MacMan's Avatar
Originally Posted by domyz
Maybe something is messed up in your ROM or XML (brainstorming guesses: scaling, axis adress, 1 byte load factor, MAF, SD bug(not likely)).
I'd try a new version of each one (XMLs and SD ROM) and copy over your relevant tables for testing.
this point aside, can you tell me the answer to my other questions? what tables need changing to move your load scale left or right?
Old Jan 18, 2014 | 03:54 PM
  #272
domyz's Avatar
These all affect load:
RPM VE
MAP VE
MAF COMP VS Coolant temp
MAF Compensation (as known as MAF Smoothing)
MAF Scaling
I don't think this points to your issue. You tried different RPM VE and Map VE values which is supposed to work .. without playing with other MAF calculations.
Old Jan 19, 2014 | 04:26 AM
  #273
MacMan's Avatar
RPM VE
MAP VE
MAF Scaling
thank you, I'll start to look over these values vs. an unaltered map to see if there have been some unknown changes made before I got to the tune.
yes, I've tried raising RPM VE back up to 100 and higher... have tried 340/430, 370/430, 400/430, 430/430... 330/460, 300/500 in MAP VE final row to no avail. the curve seems to only move 10 load one way or the other. My pump tune is 600hp 29psi... e85 is close to 800 at 42psi... but both pulls are nearly identical on load curve.
Old Jan 19, 2014 | 09:14 AM
  #274
domyz's Avatar
Also if you change values in the MAF tables, go with MAF compensation and not MAF scaling. The MAF scaling curve should stay round and smooth in the graph option.
Old Jan 20, 2014 | 09:50 AM
  #275
MacMan's Avatar
RPM VE
MAP VE
MAF Scaling
I did find a difference from virgin V7 rom in MAF COMP VS COOLANT
my table is on right, stock is on left. Might this be my issue, and why would this table be changed? I notice they're both the same at operating temp, so I don't think this is it.
Old Jan 20, 2014 | 12:31 PM
  #276
domyz's Avatar
It's not your issue. If it has changed, it's because someone edited it or "post primer enrich decay" which is the same table.
I'd still flash a new ROM with a new XML pack installed. It can be something you won't see easily.
Also, what do you use for air temperature ? AIT, MAT or Fuel temperature? Do you have any good reading of it in Evoscan? It came to my mind because if it is unconnected or bad ground, the load would be affected. It's just another guess but still worth checking.
Old Jan 20, 2014 | 12:50 PM
  #277
MacMan's Avatar
Using fuel temp for AIT. I can log it if you can tell me where.
Old Jan 20, 2014 | 03:22 PM
  #278
domyz's Avatar
MUT 11 (request ID 11)
formula: 1.8*x-40
output is deg.F
Old Jan 20, 2014 | 05:21 PM
  #279
MacMan's Avatar
formula: 1.8*x-40
output is deg.F
excellent, I'll get a log in the morning on the way to work. Thanks domyz
Old Jan 21, 2014 | 07:37 AM
  #280
MacMan's Avatar
haven't done the log for fuel temp yet... but look at this
Top pic is with load1byte selected...bottom is with load calculated selected in Evoscan...
THIS is where I'd like to see my car on the load scale... this is how my old Evo load scale ran on a MAF tune. and THIS car was only 450whp.
Old Jan 21, 2014 | 09:07 AM
  #281
domyz's Avatar
As I already said it could be your 1byte load factor..
What is your 2byte to 1byte load factor in the ROM
and
What it is in Evoscan (load 1byte formula) ?
They should be the same
Old Jan 21, 2014 | 11:33 AM
  #282
MacMan's Avatar
and
In Evoscan, the 1byte load formula is
Req. 41
1.2*x
in my rom it's 1.8. THERE'S THE PROBLEM, TAA DAAAAAAAAAAAAAAAAAAH. THANK YOU THANK YOU THANK YOU THANK YOU~~~!!!!
OK. so what do i change them to. I see in another thread, someone says to make them both 1.5, is this correct?
Old Jan 21, 2014 | 12:28 PM
  #283
domyz's Avatar
Max load is calculated like that.
1byte=8bits,
in binary terms it's a "word" (00000000,00000001, 00000010, etc...)
so 256 possible values including zero
max value is 255
So load conversion factor:
255*1.2=306 max load
255*1.4=357 max load
Yes I'd put them at 1.5. In SD it doesn't really matter because you still can adjust load curve with VE tables. But with a stroker and big turbo, more load will be somewhat easier to tune, and more realistic vs MAF tune.
Old Jan 21, 2014 | 12:33 PM
  #284
MacMan's Avatar
1byte=8bits,
max value is 255
Thank you sooo much for your help Domyz, what a blessing to have such a supportive community behind us.
Old Jan 21, 2014 | 02:16 PM
  #285
MacMan's Avatar
yep, that did the trick. Thanks again. bro.
Quick Reply: How To: Speed Density on the evo8 using tephra v7/Phenem pre-patched roms
