How To: Speed Density on the evo8 using tephra v7/Phenem pre-patched roms
#77
#78
i would just like to give EVERYONE a huge THANK YOU with all you did with the speed density on the stock ECU. i got my car dyno tuned last night and the driveability on the car is absolutely UNREAL. its by far the smoothest car ive ever driven in the 5 years of owning it!!
dyno thread:
https://www.evolutionm.net/forums/ev...r-powered.html
dyno thread:
#80
Hey guys I have a question. When I open ECUflash it wont let me view the SD tables. I can open them up but they are only about an inch wide and I cant see any of the values nor can I enter any into the table. Did I maybe download tephra incorrectly? Any help would be greatly appreciated.
#81
did u rename both the xml files when you put them in the evo folder? only rename the one to 96531706 and leave the other at tephramod-*********-v7 or however it goes. i had the same problem
#84
i've done the SD conversion and I'm using an omni 4 bar and GM IAT with the SpoolinUp harness and the 96533706 v7 rom but I get the following DTC code and any suggest why, I don't get them with the other 9653xxx roms
Diagnostic Codes:Oxygen Sensor
Intake temperature sensor
Throttle position sensor
ISC motor position sensor
Engine coolant temperature sensor
Crankshaft position sensor
Camshaft position sensor
Knock sensor
Injector circuit
Fuel pump relay
EGR sensor
Thanks
Andy
Knock sensor
Injector circuit
Fuel pump relay
EGR sensor
Thanks
Andy
#85
Knock sensor
Injector circuit
Fuel pump relay
EGR sensor
Thanks
Andy
Knock sensor
Injector circuit
Fuel pump relay
EGR sensor
Thanks
Andy
#90
when i flash the sd rom to my car i get the list of errors i posted above. the car runs ok but wondered if anyone can tell me why i get them, so that i can remove my mil light. and go sd for good.
