unknown rom image
Old Dec 18, 2009 | 07:48 PM
RoadSpike's Avatar
Originally Posted by adcgn45
ahh thank you ill get that for u asap
Well i have a dinner appointment here so i'll be out for awhile perhaps one of the crowd will recognize the rom. You may also be able to Google it for an XML def if it isn't too screwed up
Old Dec 18, 2009 | 07:52 PM
adcgn45's Avatar
ok 96940013
Old Dec 18, 2009 | 08:01 PM
adcgn45's Avatar
from what ive gathered its a factory mitsu rom which is much like the 96940011. with a maybe some debugging. i dont know where to go from here though.
Old Dec 18, 2009 | 08:08 PM
ace33joe's Avatar
I guess you can try either copy 96940011 XML file and make a 96940013 XML file or just temporarily rename the 96940011 XML file to 96940013 and see if you can read tables correctly.
The file locations is C:\Program Files\OpenECU\EcuFlash\rommetadata\mitsubishi\evo
Hope this helps.
Old Dec 18, 2009 | 09:30 PM
racer135's Avatar
adcgn45,
Check your email. Let me know if you have any problems opening it.
Old Dec 18, 2009 | 10:46 PM
logic's Avatar
It's a newer version of the 9694 line-up. Anyone with a USDM '05 should be getting that image flashed from the dealer if the car ends up there for service.
96940011 is close, but a bunch of stuff moved a small amount. Some tables will appear correct, but there's a lot that will look garbled (if memory serves, axes in particular got shoved around a bit).
At some point, I'll probably sit down with the stock 0011 EcuFlash definitions and try to locate all of it's tables in 0013, just so people new to this aren't thrown in the deep end of changing their ROM right off the bat. There's not that many tables.
(I've actually been meaning to do a diff between 11 and 13, just to see what changed. I'm curious what was important enough to issue an update for this late in the game.)
Old Dec 19, 2009 | 01:02 AM
ace33joe's Avatar
Oh, I didn't know that Mitsu did another update for 05 EVOs. I thought 96940011 was the latest one, and he was mentioning tuner locking out, so I thought some tuner did some trick on the ID number. But I hope 96940011 and 13 share most maps, so that he can start looking at some tables.
Old Dec 19, 2009 | 04:48 AM
racer135's Avatar
Maybe its P0300 related. But honestly if you don't know exactly what you are doing I would read a lot in this forum or get some local help before doing any changes. You can always go Tephra V7.
Old Dec 19, 2009 | 07:04 PM
adcgn45's Avatar
so what should i do reflash it with 11?or what?
Old Dec 19, 2009 | 08:25 PM
ace33joe's Avatar
I don't think you want to reflash 11 rom. You can just try 11 XML to view 13 rom's tables if most tables use the same addresses.
Old Dec 20, 2009 | 03:12 PM
adcgn45's Avatar
ugh this is a pain in the ***.i just wanted to do some minor tuning and i cant even open this thing. i read all the tutorials and did a lot of reading but nothing guides you through something like this
Old Dec 20, 2009 | 07:31 PM
ace33joe's Avatar
As I said, if 13 and 11 shares lots of tables, you can still do minor tuning. Try 11 XML. XMLs themselves do not affect the rom you have unless you make changes to the rom, since it is just a definition file.
Old Dec 22, 2009 | 02:09 PM
adcgn45's Avatar
still not sure what to do with this 11 i have.can someone guide me through a little?
Old Dec 22, 2009 | 02:23 PM
RoadSpike's Avatar
He basically just wanted you to copy the definitions from the 11 rom so you have an xml for the 13 rom.
I did it for you just download it into your rommetadata\mitsubishi\evo folder
Exact location:
The file is an attachment here as a zip file good luck
File Type: zip
Old Dec 22, 2009 | 02:44 PM
logic's Avatar
If you'd rather not just download something from the Internetwebs, you can go to C:\Program Files\EcuFlash\rommetadata\mitsubishi\evo and copy the file 96940011.xml to 96940013.xml. Then, open the new file up in notepad, and change the lines near the beginning that say <xmlid>96940011</xmlid> and <internalidhex>96940011</internalidhex> to be 96940013 instead of 96940011. That's pretty much what RoadSpike did in his version.
If that doesn't work out well (and I suspect it won't), rather than downgrading to 96940011, you might be better served by just switching to tephra's v7 release, although that's a hell of a first introduction to flashing.
See the wiki for information on switching from 96940011 to 96530006; that's pretty similar to what you'd need to do to switch from 0013 to a 9653 tephra ROM.
Quick Reply: unknown rom image
