Idle position switch on/off in Evoscan - big problem
Hello. At first I want to wish all of You Happy New Year ! ![Cool](https://www.evolutionm.net/forums/images/smilies/cool.gif)
Now - my problem is, that in column "idle position switch" my value is still ZERO.
I had problems with my electric harness - nb o2 sensor was disconnect from my ECU, but I fixed it. Then I've discovered this "idle position switch" problem. Evoscan still showing zero. I guess it should said "on" or "off" ?
It's really bad, because my car doesn't have idles and throttle response @ driving is very, very agressive.
Thx for answer. If You are sure, now I have bigger problem because I have really no idles. Maybe I should put some stock-set ROM, but I do not have any. Can I put some base tephra rom for start ?
No , open evoscan (dont start logging) ,start the eng let it idle , on the right hand side see actuators on the bottom select speed adj mode ,then turn the air bypass screw in the throttle body in to slow down idle or out to speed up idle to around 850rpm ,de activate then .
