Maf Rescaling
Old Jan 3, 2010 | 07:11 AM
Stradag's Avatar
Maf Rescaling
I was reading through a tuning book that I bought off amazon. It said that you can rescale maf sensors when you max it out or it is "pegged". It said when you rescale the maf sensor your supposed to adjust the size of the injectors corresponding to the amount you adjust the maf scaling. It also said that rescaling your maf sensor will through off your calc. load readings unless you adjust the displacment of the motor in the ecu? Has anyone heard of any problems like this when rescaling the maf? Can anyone explain exactly what uses the maf scaling tables, as well as maf compensation tables. Is there more to rescaling the maf than just looking at fuel trims and adjusting the maf scaling table?
Old Jan 3, 2010 | 07:54 AM
chmodlf's Avatar
Use the search button young jedi...
https://www.evolutionm.net/forums/ec...hout-pics.html
Old Jan 3, 2010 | 09:16 AM
todd6027's Avatar
why do you want to rescale it ???
Old Jan 3, 2010 | 09:56 AM
Stradag's Avatar
I have stock injectors HKS Intake, 280cams, exh. ect. My fuel trims are around +12 to +11 I would like to get them at least near 0.
Old Jan 3, 2010 | 09:59 AM
Stradag's Avatar
chmodlf, I know how to rescale the maf, but I was wonding if the maf scaling and maf compensation tables could through anything else off, like calc load.
Old Jan 3, 2010 | 05:26 PM
chmodlf's Avatar
no the maf scaling does not figure in the loadcalc
5*InjScaling*([InjPulseWidth]-(-0.1026*[Battery]+1.8741))/[AFRMAP]
mplspilot
Dec 5, 2016 04:29 PM
Gexxer
Sep 29, 2010 08:00 PM
Live4Redline
May 13, 2009 08:57 AM
steadly2004
Feb 25, 2009 01:05 PM
Kierkegaard
Aug 14, 2007 10:31 PM
Quick Reply: Maf Rescaling
