injector scaling 450cc help
they should be the same as the DSM injectors. try looking on Ceddy's webpage he has the Eclipse rom dissimbled you should be able to pull the scaling from that. www.ceddy.us
Be aware that I use a different Injector Scaling in my XMLs.
I have it 450 = 450cc/min
850 = 850cc/min
etc.
The Evo guys use a different scaling:
513 = 560cc/min
etc.
450cc/min in Evo scaling would be 424
Latency for DSM 450s:
850 = 850cc/min
etc.
513 = 560cc/min
etc.
![Name: 450Lat.png
Size: 40.1 KB](https://www.evolutionm.net/forums/attachments/ecu-flash/145287d1262645752-injector-scaling-450cc-help-450lat.png)
hi ceddy
i try to change the injector latency . but the volume run a way from i set it ... why be like that ?
is mean i set 3.825 then come out is this volume 3.816 ...
not only one all also like that i mean the cell .....
If you mean the top cell of the Latency won't go higher is because it's maxed out.
Just leave it at the the highest value it will take.
The Latency values won't match exactly be cause the Evos and 2G DSM use a different DeadTime Multiplier(Evo=24, 2G=15).
But you should be able to get them with in a few thousandth of each other.
Just get them as close as possible.
