Ecu flash help
Old Jan 6, 2010 | 03:02 AM
jdmevo123's Avatar
Ecu flash help
Hi all
I need help on a flash I got done. The immobilizer hex code is incorrect after put the tether mod on. It does not tell the sequence for the jdm evo 8 and it is currently on 0x0040.
My car currently won't start and sounds like the fuel pump won't kick in.
Car is 2003 evo 8 jdm. The tethra mod uses 2005 Mitsubishi base file.
Anyone know how I get the correct hex so my car will start.
Thanks
Dale
Old Jan 6, 2010 | 03:53 AM
And's Avatar
And
you should be able to look in the original map that was on the car and the immob information should be in there, then copy the values across.
Old Jan 6, 2010 | 04:44 AM
jdmevo123's Avatar
I have looked at the origional map and the immobilizer hex key table does not exist.
Old Jan 6, 2010 | 08:16 AM
And's Avatar
And
what version is your original rom? you'll probably need to edit the xml file to get it to show the info. Have you tried to set the immob bit in the tephra rom to 0 to disable the immob and then see if it starts? bit 3 in the FAA table near the bottom.
Old Jan 6, 2010 | 06:04 PM
jdmevo123's Avatar
Hi Thanks,
I did turn FAA bit 3 to 0 and the car started, i still through some cel codes,
Updated: 00:14:52
6 Diagnostic Trouble Codes Found:
P0141 Heated Oxygen Sensor Heater circuit Bank 1 Sensor 2.
P0505 Idle Control System.
P0403 EGR Solenoid.
P0243
P0090
P0513
I am using map 93660005.xml
Old Jan 6, 2010 | 06:05 PM
jdmevo123's Avatar
sorry meant 93660005.xml is my old ROM and now I have the thethra rom.
razorlab
5165
Aug 11, 2024 08:56 PM
nuk1ear
Nov 27, 2016 06:13 PM
Evo_Goodness
Aug 12, 2016 12:34 PM
ihearthondas
Lancer Troubleshooting
29
May 7, 2009 08:15 PM
Stradale
Sep 1, 2008 08:09 AM
Quick Reply: Ecu flash help
