DIY - Trip computer
#61
Sorry Bobby, I have no useful input right now, since the car this is going into isn't running right now. (The battery is beyond dead at this point, and when I parked it the starter was toast and I suspected a spun bearing. )
FWIW, with it on the bench, I can rotate through the screens on mine and see at least voltage and temperature (I had one temperature sensor hooked up). I managed to get the unit into some kind of weird state where it wouldn't switch between screens at one point, but I have no idea how I fixed that; it started working again after I ran through the setup screens a second time.
Can you describe exactly what you're seeing on each screen? (It sounds like you have it wired up correctly.)
#62
I did the same thing and wondered why it wouldn't switch.
You have to go back into the 'group' options and enable them all for either 'parked' or 'drive'.
The words in ''s I may be making up though as I can't remember off the top of my head
#63
That sounds familiar. If memory serves, I ended up going back in there and selecting "default groups" at one point, and that may have been when it started working "properly" again.
(I've probably spent a grand total of five minutes looking at the docs at this point, so that probably would have jumped out at me eventually. )
#65
On the different screens, I get these displays:
1st screen: temp and voltage
2nd: 384km (only one that works) with 0.0L
3rd: 0.0L 0.0km
4th: 0.0km 0.0L/100km
5th: 0.0$ 0.0$/100
Speed also works, but I can't remember which screen that one was on to label it correctly. I did all of the settings they said to do in the instruction manual Ed sent me on the last page.
3rd: 0.0L 0.0km
5th: 0.0$ 0.0$/100
#66
Location: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
I think you crimped wrong wire, please check it again,
if you have injector correctly wired then you will see L/h and L/100km
If you have fuel level correctly wired you will see also how many km you have till empty.
It seems you have only vehicle speed wired correctly.
#69
If it's any consolation, I'm having some difficulties getting the fuel level and VSS signals to do anything useful on the WRX version I installed today in my wife's car, but some of that has to do with the fact that I never received installation instructions for it, and have been winging it based on wiring docs and guesses about how the trip computer should be set up.
For your installation, the VSS is obviously working, so it's down to the injector and fuel level signals.
Are you using those cheesy vampire clips they provided? (I hate those things, even though I ended up using them on my wife's car for testing; they're just unreliable garbage. Now Posi-Lock connectors, those are actually pretty cool.)
Do you have a multimeter that you could use to test the fuel level signal at the trip computer with (just unplug the TC, and test the terminals on the harness; it should just be a 0-5V signal)?
You won't be able to test the injector signal that way, unless your MM has a peak hold function (or you have a handheld scope lying around ), but it'll at least tell you about one of the problems you're having.
(If all this is obvious stuff and I'm just suggesting things you've already checked, go ahead and tell me to hush up. )
#70
Finally got around to checking all my connections and troubleshooting, it turns out it was one of those chinsy connectors. It tested good on the ecu side then bad on the other for the fuel level signal. I was in a rush when I installed this thing, thankfully that's all that it was, all good now!
#71
We Evo guys should consider ourselves lucky; mounting the WRX trip computer involves zip ties. Seriously. (It looks nice once you've installed it, though, although the green doesn't quite match the other gauges.)
Looking at the Kiwi, it's interesting (although a slightly different product), but at a significantly higher price point, and from what I can tell, doesn't have an OEM-style installation like the SERG unit does. (That's one thing that really sold me on it; it looks like it belongs in the dash once it's installed.)
I'm not so concerned about "trust" here; I'm not basing tuning decisions on the stuff the trip computer is displaying. A wideband, sure; I need an accurate sensor (Bosch or NTK) and a solid interface to it. But a trip computer? Meh. Ballpark estimates are more than good enough for me.
#72
Cool, good to hear; I ended up using those damned vampire clips on my wife's car, and nothing is reading correctly there either. I just haven't had enough time to go back and rewire it properly.
Speed Element
Evo 'For Sale' Exterior Styling
476
Jan 20, 2016 12:51 PM
