How much timing for Evo 8 Peak
the op's asking what your timing maps set to not your actual logging of timing
racer135.....have you done any adjustment to the knock sensitivity? It could be that because of your mods the stock settings are "too sensitive".
You should be able to run more boost than just 23....I am talking 25ish on 93.
My VIII on 93 will take 4 to 5 degrees at peak torque (310 load at 26-27psi) and I am in the low to mid teens up top.
It almost sounds like there is something mechanical wrong.
As for getting more torque out of the car, try to get your turbo to spool sooner (lower RPM) and give it a little more boost.
I wouldn't be ****ing with those settings. If you're that paranoid look at your timing, if its true knock the timing will retard.. also log the voltage for knock like mentioned also. if you have huge spikes, then chances are its real.
Oh I wasn't planning on messing with the settings really. I think I might have phantom knock or something.
just look at your logs.. does your timing get pulled where the ecu is registering knock counts? if so its real knock. i would log voltage though and see if the knock sensors doing its job.
MBT is a static number...in our case because of bore and head design about 19*
If I could run 19* at peak torque I would, but anything less than methanol probably won't let you do that.
To answer your question, I quote Douglas Adams "Reality is what you get away with".
reality=knock on pump fuel
I think you mean that the crank angle for peak pressure achieving best torque is a static number. But the timing needed for combustion to achieven that peak pressure at that static crank angle changes with various factors such as AFR, fuel, RPM, etc.
I'm sure you meant that, but wanted to clarify for anyone reading.
cliffs- this why we run more up top than down low.
Kind of off topic but is this true? I thought phantom knock still pulled timing and the only way to tell was to watch knock voltage? I don't have any clear logs to show this and thats why I ask.
Any knock will retard timing. And you can't distinguish between the two simply by looking at knock voltage.
all voltage comparing does is confirms if its bad knock or not, from what i gathered if its bad knock the voltage will spike, if its weak knock it will show little voltage...
you're at the knock sensors mercy basically, and you have to rely on it.
ya.. i was getting confused with when i used to tune with a pocketlogger and look at the timing activity and see where its knocking..
Check the knock sensitivity tables thread for more info.
I almost bought your purple 2g years ago, infact i visited your site and almost **** when i seen you were the same guy with that ams 2g... small world.
