Ignition timing, cam or crank sensor
This might be a silly question, but...
Is the ignition event timed directly from the cam angle sensor? I was under the impression that it used the crank trigger, and only the crank trigger.
d
d
Here is the answer
I'm trying to figure out why I have to run _much_ less timing on E85 than everybody else seems to. However I am running the and exhaust cam gear at -3 degrees, so my numbers are probably 6 degrees off crank TDC...
d
heyythurr
Nov 3, 2014 12:52 PM
elhalisf
Jun 15, 2013 07:10 AM
