JDM EVO 7 ecu def help.
Using ECUflash I read from ECU and got the following Task Info and hex dump in the attached files. There is no ECU definition for it. I tried inheriting and copying from stock definitions without success as the "Current ROM Metadata" looks empty.
I get the same problem if I save the hex dump from Evoscan and try to open it in ECU flash.
Can anyone assist so, that I can begin to edit the maps?
Hiboost
15
Jan 10, 2016 10:15 PM
