P0069 dtc???
P0069 dtc???
Ok so I just installed a 399 maf I bought off another member on here to replace my stocker which was fine but restrictive compared to the 399. I also at the same time pulled my stock ecu and installed a evo 8 ecu, now I am getting the DTC 0069 talking about the map sensor?? I know my map sensor is identical to the evos and was perfectly fine before the swap. Does this mean the maf I bought is no good?
Ok so I have determined through various tests that all my sensors and my evo maf are fine. Would this DTC happen if this ecu was setup to run a 3 bar map sensor and I have a stock one? and how would I check this? any and all help is majorly appreciated
BadazzCR
Aug 23, 2008 07:40 AM
