How do you "shrink" the actual sizw of a displayed 3D map?
I want to shrink the size of my timing and fuel maps so that I can actually view them where I can see RPM and all load tables... I am running 96530706 and I saw when I loaded up 94170015V7, I was able to view the entire 3D table on my screen... I have a small *** sony and every time I have to adjust a map I have to move the map over every time to view which RPM row I am in... here is a comparison...
Plus when you pull up the 94170015V7 fuel map it isn't displayed like the timing map it is off the screen like the rest of the V7 maps, which also throws the RPM scaling idea out... It has to be something in ECUflash that defines how a map is displayed...
Quoted again for truth infinity
You didn't look close enough, grasshopper.
Look at the max and min values for the timing scaling for your 94170015 and then for your 9653 ROM.
I would be willing to bet that one of them has their max/min set to -128/128 and one has it set to -61/61. If you change the other one to -61/61 and reopen the ROM, it will be a smaller map.
Eric, my bad, I was looking at the wrong row! Yes the 9417 timing scaling is set up to -55 & 55, the 9653 is set up -128 & 128 changed and fixed. Thank you sorry I doubted you However I can view the entire timing map now, I can't view the enire 3D fuel map... any suggestions?
What's the max resolution on that netbook of yours? I'm thinking of getting one, since MY GIRLFRIEND's ****ty 15" is a pain to lug around, plus it gets about 40 minutes of battery. The netbook I'm looking at has a 1366 x 768 max display res.
Would somebody mind throwing up a screenshot or typing an example xml so that I can see the changes. I've been drinking too much and have lost all analytical skills about 3 hours ago.
