Need help no start after flash attempt.
Helping a friend de-mod his 2004 evo8 from AEM to my old ecu from my own 2004 editing rom file with evo scan and came up with this.
flashing tool "mitsukernel" loaded.
flashing tool "mitsukernelocp" loaded.
flashing tool "mitsubootloader" loaded.
OpenPort Cable Connected.
image file is incorrect size.
3392 byte kernel read.
sending init sequence 1 (0001)
sending init sequence 1 (0003)
sending init sequence 1 (FFFF)
sending init sequence 1 (F0F0)
got 0x05 response
sending init sequence 2
got 0x1B response
sending init sequence 3
entering bootloader
sending kernel size (3392)
sending kernel load address (0xFFFF8800)
uploading kernel
verifying kernel checksum response
kernel valid
kernel get version
kernel version is : OpenECU Mitsubishi SH7052 Kernel V0.21
Flashing image to ECU memory...
comparing ECU flash memory pages to image file
segment len ecu CRC32 img CRC32 same?
FB01 00001000 C71C0011 C71C0011 YES
FB02 00001000 C71C0011 C71C0011 YES
FB03 00001000 C71C0011 C71C0011 YES
FB04 00001000 C71C0011 C71C0011 YES
FB05 00001000 C71C0011 C71C0011 YES
FB06 00001000 C71C0011 C71C0011 YES
FB07 00001000 C71C0011 C71C0011 YES
FB08 00001000 C71C0011 C71C0011 YES
FB09 00008000 011FFCA6 011FFCA6 YES
FB10 00010000 D7978EEB D7978EEB YES
FB11 00010000 D7978EEB D7978EEB YES
FB12 00010000 D7978EEB D7978EEB YES
flash image is identical! exiting.
interface close
What did I do wrong?
Do I need to do the writing in my car then transfor to his?
Main goal is to disable immobilizer and run with stock parts.
Please any help will be great. Thanks
got 0x05 response
got 0x1B response
entering bootloader
uploading kernel
kernel valid
kernel get version
interface close
EvoM Community Team
You can flash with an incorrect immobilizer. You did not write the image, you simply compared the image you had open to the one that was on the car.
Click the right button next time with the correct/disabled immobilizer and everything should be fine . Also, reading the log might help!
Can't read dtc's or datalog. Tried writing a rom with no luck also.
Apparently i am the only one that can pick up on Fost's sarcasm. Read the ecuflash log please... whatever you were flashing was the same as what is on there. Ecuflash only flashes changes in the rom, if there are none there is nothing to flash.
MonacoGP
Apr 8, 2011 02:06 PM
