Enabling Alt Maps
How about 93%, will that work to activate alt. maps?
Being there is no way to adjust the TPS sensor on the BBK. I may take the sensor off and use a dremel to notch the screw holes, allowing me to hopefully rotate it to increase the TPS %.
Sorry for resurrecting an old thread but I've tried searching and can't find an exact answer to my question.
My question is... Can I switch maps on V7 while the car is running if I'm using the ICS button for map switching? I'm pretty sure the answer is yes but I just wanted to see if I could get a difinitive answer from someone. Thanks in advance.
07EvoIX
Oct 28, 2012 12:49 PM
