Need help with High AFRs
#77
If I havent said it yet I greatly appreciate you guys taking the time to help me figure this all out.
#80
I think I understand, so what your saying is pretty much at 2500rpms whether the load is 100 or 190 the afr will be the same because of how a turbo spools up? This makes sense. I did something similiar to the map you posted, I changed every value I had below 10.1 and raised it to 10.1 with absolutely no change to my actual afrs. This is the response I expected from the ecu confiming the 10.01 bottom afr value it reads. Is there any other way to add fuel other than lowering fuel map and raising maf scaling values?
bsbllfit7
Nov 24, 2014 08:31 AM
