Ecuflash connection problem
I'm a newbie with tuning. I dl ecuflash and I have a open port 2.0 tatrix cable. I'm trying to get a stock rom read. When I open up Ecuflash, select my vehicle 3rd gen evo, and then start reading I receive an error and the logging stops. What am I doing wrong???
I have now done more research. I have gone back and went into add/remove programs and deleted previous dl ecuflash and tatrix drivers. I have dl Ecuflash unlocker from active matrix.
I have tried to read the rom again and this is what i got. The only thing I can think of is my car battery is low. Any suggestions would be awesome!! I'll even take over the phone advice my names Fred 248345-4809.
Any help or suggestions would be greatly appreciated
[23:19:45.923] EcuFlash Version 1.42.2595
[23:19:45.923] OS Version Windows Vista
[23:19:45.923] Qt Version 4.5.0
[23:19:45.939] 56 memory models read.
[23:19:45.939] scanning for metadata models in C:/Users/DurstMan/Desktop/EcuFlash/rommetadata
[23:19:46.407] 343 ROM metadata models scanned.
[23:19:46.407] checksum module "subarudbw" loaded.
[23:19:46.407] checksum module "mitsucan" loaded.
[23:19:46.407] flashing tool "wrx02" loaded.
[23:19:46.407] flashing tool "wrx04" loaded.
[23:19:46.407] flashing tool "sti04" loaded.
[23:19:46.407] flashing tool "sti05" loaded.
[23:19:46.407] flashing tool "mitsukernel" loaded.
[23:19:46.407] flashing tool "mitsukernelocp" loaded.
[23:19:46.407] flashing tool "mitsubootloader" loaded.
[23:19:46.407] flashing tool "shbootmode" loaded.
[23:19:46.407] flashing tool "shaudmode" loaded.
[23:19:46.407] flashing tool "subarucan" loaded.
[23:19:46.407] flashing tool "mitsucan" loaded.
[23:20:01.196] J2534 API Version: 04.04
[23:20:01.196] J2534 DLL Version: 0.50.2598 Jun 26 2009 15:02:29
[23:20:01.196] Device Firmware Version: 1.10.2658
[23:20:13.853] sending init sequence 1 (0001)
[23:20:17.161] sending init sequence 1 (0003)
[23:20:20.468] sending init sequence 1 (FFFF)
[23:20:23.775] sending init sequence 1 (F0F0)
[23:20:26.521] no response to any known code
[23:20:26.521] interface close
its getting to the init sequence so it could only be a couple of things. Your battery is low, try to charge it up and pull it again. Second, your rom is locked and you need the unlocker found here: http://www.aktivematrix.com/forum/dl...gory&cat_id=11. Or your car is not in the On position but not started.
MR Turco
Nov 27, 2021 08:08 PM
