Latest EcuFlash beta, now EvoScan not working. Anyone else?
Anyone please know why Ecuflash 1.43.3150 closes down without any reason or when I try to read a rom or after few seconds after the rom is finally read?
I look over a xml issue but I do not think this is the problem.....
Everything was ok until I`ve install the beta version. I try also to go back to 1.42.2595 but now OP2 is not working anymore with the newest drivers as Ceddy said.
Thanks a lot,
Daniel
Thanks a lot,
Daniel
I am having a similar problem with ECU Flash's new beta, I downloaded it from the Evoscan website when I upgraded from 2.6 to 2.7. At first it was working perfectly and I was really liking the new features of the slider bar and changing the wording to a different color for changes. But anyways when I go down past "Global Boost Control "Type"/ Choose LOAD or PSI Targeted Boost Control" the program force closes on Windows 7. It does this every time.
i found with the v7 rom if you remove the line
<table name="== EDIT THE TABLES BELOW FOR LOAD OR PSI BOOST TARGETING ==" category="Global Boost Control 'TYPE' (Choose LOAD or PSI Targeted Boost Control)" address="0" type="1D"/>
then they work not sure why as the xml looks correct but it must be the way its being interpreted
Andy
Andy
Damn Andy you are bad ***, this worked perfectly. I took out the whole line that you posted above and now it works perfectly. Now if I can figure out how to get the graph to show up when using ALT-G or clicking "View" than "View Graph"
I'm late, I know....I just found my way into stand along logging, and part of that is using the beta to update my firmware on the OP2. I found this thread while looking to, what I think is report a bug, but in my expierience if there isn't a scaling assigned to a specific item...it bombs out.
Perhaps on the "it still crashes on other xmls" thing, there is a line without a piece such as scaling="Hex16" or whatever the specific case might be. Seems like a bug, or at least worth mentioning though, since it hasn't been a problem in previous versions.
richardjh
120
Oct 6, 2017 08:58 AM
evoscan
52
Jun 20, 2017 01:46 AM
xPRimNT
239
Jun 2, 2016 10:40 PM
evo4mad
May 5, 2015 06:22 PM
