1350cc Scaling help & Cyl 1 Misfire
I think I've got mine dialed in pretty good, but I was wondering what other ppl have. Mod list is in my sig and Im on E85.
**UPDATE**
I've got the injectors in pretty good. Cold starts are near perfect like pump gas and cruising is fine. Except for the fact that my idle is rough. Everything seems fine now. No CELs anymore thank goodness... But here are my trims. I read a little bit on the other thread and noticed that the 11v in the Latency table will help with my idle, but the 14v would also change the whole trim.
My scale is 696 : Again, these are the BlueMAXX 1350cc injectors on E85
Latency:
4.69v= 4.344
7.03v= 2.160
9.38v= 1.680
11.72v= 1.104
14.06v= .888
16.41v= .696
18.68v= .408
...with those settings I got Mid -8/ Low +8
So whats next? From the very little knowledge I have, I going to..
11v= 1.224
14v= .864
Yay? Nay?
**UPDATE**
Latency:
4.69v= 4.344
7.03v= 2.160
9.38v= 1.680
11.72v= 1.104
14.06v= .888
16.41v= .696
18.68v= .408
11v= 1.224
14v= .864
Yay? Nay?
tinker around some more today and the code went away! yet I still idle fairly lean. anyone have any ideas or maybe some latencies I could use? I found the SUBMERGED thread with all the scales, but couldnt find any for 1350cc blumaxx =/
Im throwing a code for P0134 now. Im trying to get that figuired out at the moment. I did replace to the o2 sensor right after it came on and its still on. I heard its possible that it comes on if you run too rich as well.
Raceghost
Jun 1, 2016 12:30 AM
illogicalmind
Nov 16, 2014 05:56 AM
