Custom EvoScan Gauges
Old Apr 25, 2010, 09:45 AM
dyezak's Avatar
I'm running a carputer in my car in a custom double-din install I did and will be running EvoScan full time to be gauges. So far this is what the install looks like, and below that is my first go at a set of custom gauges that will be running in it (inspired by the Lexus LFA tach/speedo:
Newest Revision:
Old Apr 25, 2010, 09:56 AM
vmrevo9's Avatar
looks pretty cool! i want to do this so bad to mine. maybe after the upgrades i have planned!
Old Apr 25, 2010, 09:59 AM
And
And's Avatar
what size screen is that?
Old Apr 25, 2010, 10:04 AM
dyezak's Avatar
8"
Old Apr 25, 2010, 10:16 AM
nudge120's Avatar
Looks awesome, are you willing to post up your template??
Old Apr 25, 2010, 10:20 AM
nudge120's Avatar
If I was inclined enough to do a custom gauge template this is the one I'd base mine off of.
Old Apr 25, 2010, 10:27 AM
dyezak's Avatar
First, yes, I'll post up the XML's when I'm done. Secondly, what car is that gauge cluster from? After I spent a few hours with DashDAQ and figured out how to import images this morning the dash above should actually be no problem. It would take a while but it can be done.
Old Apr 25, 2010, 11:18 AM
nudge120's Avatar
Its the cluster from the Koenigsegg Agera. I look forward to you sharing your work, thanks.
Old Apr 25, 2010, 12:31 PM
dyezak's Avatar
I think I'm getting the hang of creating these. I was able to create a temp gauge in the shape of a thermometer in about 10min, then add it to my current dash. I put two of them in, one on each side, one for intake temp and one for coolant temp...
Old Apr 25, 2010, 07:06 PM
mfr122887's Avatar
Are you using DashDAQ gauges with EvoScan?
Old Apr 25, 2010, 07:18 PM
dyezak's Avatar
Yup, just using DashDAQ and EvoScan to make my gauges, and GIMP to make the images to inlay into the Gauge Clusters. Here's where I am at now, on the left is coolant temp and the right is intake temp (haven't done the labels yet):
Old Apr 25, 2010, 07:20 PM
mfr122887's Avatar
DashDAQ templates are compatible with EvoScan? Can they be loaded from the EvoScan menus?
Old Apr 25, 2010, 07:26 PM
dyezak's Avatar
I'm sorry, I am mistaken. It's not DashDAQ, it's Dundas Gauge for .NET (the one EvoScan comes built with).
Old Apr 25, 2010, 07:39 PM
MR Turco's Avatar
love it, just needs knock output
Old Apr 25, 2010, 08:31 PM
dyezak's Avatar
Knock was there, but hidden...I'm still working on more to add to this without cluttering up the display and thinking about changing the Boost/AFR display to look like the Ford Fusion side gauges.
Things I still want to do:
1. Add shift light
2. Add alt-map indicator
3. Change Boost/AFR to look like Ford Fusion side gauges
4. Possibly change coolant/intake temps to be like the Fusion gauges too
Ford Fusion Gauges:
Quick Reply: Custom EvoScan Gauges
