Evoscan reading 6.00 AFR with LC-1 why??
Hello,
I have been trying to log AFR with evoscan for 2 days now and it just won't work I get 6.00 AFR with WB02 with my evo running if I remove the BD9 cable from my laptop it reads 0 I am not using a USB converter the BD9 goes direct in to my laptop if it makes a difference. I selected LC-1 in WBD menu and yes my com port is selected and correct from the menu.
Now if I go into Logworks3 and select the same com port that I am running in evoscan It reads AFR 100% perfect 14.7 . So if logworks3 works perfect my comport is ok and I also have no trouble with the cables since it work perfect in logworks3,
I tried evoscan v2.5 and v2.6 running windows XP and also tried many restarts.
With my LC-1 I did not use analog out 1 and analog out 2 do I need to connect them ?? I bought the LC-1 with out gauge I just want it to log fuel in evoscan that's it. with out analog's it still reads perfect in logworks3.
HELLLPPP ????
HELLLPPP ????
Yes I did calibrate twice to be sure. I think the problem is coming from evoscan. I was thinking the com prot in device manager was the problem but logworks3 uses the same port and it works perfect.
I just found this I will try it tomorrow hope it works.
https://www.evolutionm.net/forums/ec...an-help-4.html
Ok I fixed it all you need to do is go in LM1 software and recalibrate from there after that evoscan will work fine if not try again and make sure it is set to gasoline 14.7 that should do it
