PLEASE HELP!!!! Disabling Immobilizer
I need to disable my immobilizer and I used this guide: http://evoecu.logic.net/wiki/Periphery_Configuration
After that I tried to open ECUflash and I got an error that popped up and said: Parse error at line 359, column 64:
unknown table data storage type [bloblist].
What do I do to disable the immobilizer????
I'm guessing you've pasted it into the wrong section
"Once you've opened the file, add the following text, just before the line at the end that says </rom>: "
put the original xml file back and see if the error disapears, also check that the original xml doesn't already have the ecuperiphery section, if it doens't paste it in again from the wiki link making sure you have </rom> on the last line.
once thats complete, open you rom in ecuflash
"Scroll down to the "ECUPeriphery" section, and open the "ECU Periphery 0 (FAA) Bits" table. You should see a table of choices, one of which is "Immobilizer Enabled?", with a "1" in the column next to it. Select the field with "1" in it, and press the "[" key to change it to a "0" instead. You should see the entire bottom half of the column show an indication that it was changed; this is normal, because you're actually changing that whole byte of information, not just the bit you just edited. "
http://www.evoscan.com/technical-veh...-configuration
