AFR changes when in different gears
Old Jul 13, 2010, 11:58 AM
  #46
Mellon Racing's Avatar
be aware that by disabling leanspool you could potentially make your existing dangerous situation more dangerous
Old Jul 13, 2010, 12:01 PM
  #47
pileofparts's Avatar
I am retarded. I edited the hex value not the bits... Trying again...
Old Jul 13, 2010, 12:04 PM
  #48
Appauldd's Avatar
are you certain you set the correct bit???
Old Jul 13, 2010, 12:07 PM
  #49
Appauldd's Avatar
Look at his rom. The LS is set way lean....stock if you will.
Old Jul 13, 2010, 12:11 PM
  #50
So now that I figured out what the hell I was doing the car starts. Will do some more pulls in an hour or two.
Old Jul 13, 2010, 12:46 PM
  #51
Kings Fan's Avatar
If you can, get someone in the car to help you log, that will help you a lot. Make the pull all the way up to 7k RPMs. Also do the pull on the same stretch of road everytime. Good luck
Old Jul 13, 2010, 01:11 PM
  #52
leecavturbo's Avatar
be careful with going lean with no changes and turning LS off
Old Jul 13, 2010, 02:04 PM
  #53
TouringBubble's Avatar
I still say it's an interpretation error. The logs posted show 6th gear around 0.2 richer than 4th ... not leaner.
Old Jul 13, 2010, 04:05 PM
  #54
Boosted Tuning's Avatar
When you turn off LS, everything gets richer, not leaner.
Old Jul 13, 2010, 04:42 PM
  #55
Appauldd's Avatar
Let Mellon know
Old Jul 13, 2010, 04:45 PM
  #56
just confirming I'm human...sure enough I was envisioning the higher cell values, not the AFR doh
Old Jul 13, 2010, 05:10 PM
  #57
Evoryder's Avatar
Has this been fixed yet?
Old Jul 13, 2010, 10:45 PM
  #58
Still working on it. Adjusting fuel a bit right now and will log some more pulls tomorrow. Flipping those bits definitely changed things.
MajesticOne
Nov 20, 2016 02:34 AM
dvd_mi
16
Mar 29, 2010 07:19 AM
bvdawg13
13
Apr 19, 2007 11:07 AM
RalliArtEvoVIII
Mar 22, 2005 04:35 PM
rt turbo
17
Aug 5, 2004 05:37 AM
Quick Reply: AFR changes when in different gears
