Using EvoScan to log crank angle sensor output at startup?
1 Post
My car has not been starting for a while. Many have pointed to the CAS but I have not thrown any relevant codes, so rather than charging into tearing everything apart to get at the thing I want to log its output to make sure it's bad/out of range. Here is a link to the thread: https://www.evolutionm.net/forums/ev...es-inside.html
My 2 options:
- Bring a scope home from work, hook up a pigtail and watch it live
- Evoscan
I logged crank angle sensor and plotted it vs RPM at startup - I'm getting pings of 1 volt with the wave form in sync with the ~80 RPM the starter is giving me. This seems adequate.
My question:
What is the proper signal for the CAS at startup, and what provisions must I make (if any) to use EvoScan to check its functionality?
How consistent should the wave form be? Is it possible that I have a broken reluctor wheel?
Cheers,
Jack
My 2 options:
- Evoscan
My question:
Cheers,
Jack
i thought my cas went bad and i was throwing a p0335 code, but in evoscan i saw a reading from the cas. After a few headaches i decide to change the cam angle sensor to rule out both. Swapped the cam angle first and it started right up. just my .02
1 Post
My issue turned out to be my immobilizer. I guess the dealership never programmed my spare key, or the transponder was damaged. It tripped my anti-theft but somehow the car started ONCE, which threw off my whole diagnostics (i thought since I started it once with that key it would not be the immobilizer)
As for the links Evoryder posted, thanks! I managed to get the car running before I got to that information. I was about to bring a scope home from work.
Only questions that remains is whether or not the immobilizer caused this phenomenon. I'll have to log my now healthy car to find out.
tvor
Aug 20, 2015 02:10 PM
dubbleugly01
Oct 5, 2006 09:32 PM
