evo vii JDM basemap?
hi guys,
would anyone here have a basemap for an evo vii JDM running stock with airbox mod and 600cfm cat.
I'll use my wideband to check how safe it is, but wouldnt mind seing what others have on this setup.
Try this: https://www.evolutionm.net/forums/ec...finitions.html
todd6027 prvided it but he's right, most of use went 90550001 and eventually to a TephraMod 90550001 ROM v5.10.
Wait long enough and Tephra might have his V 7 ROM out for us.
excellent, okay what I'm stuck on now is how do i disable NTLS ???
I disabled valet by setting "valet mode enabled" to 0. and i set the immobiliser to FFFF by editing the data value, but how do i disable NTLS?
I'm running 90550001 v5.10, in the mods table you set the NLTS option to 0 as well.
Then save and reflash.
There's a bug in 5.10 I believe where it won't remember the setting, I had this drama with the Valet-mode resetting itself on ignition each time.
The fix for that is to edit your 5.10 map, turning it off and save that.
Reflash the car with your old non-5.10 map, start it, then turn off, reflash with the 5.10 map you've just turned off the features on and restart that again and you should be good to go.
razorlab
5165
Aug 11, 2024 07:56 PM
TheCMan
Jul 11, 2016 05:03 PM
