how does one find where things are in mut?
hey, i'm high jacking your thread for literally 30seconds. Can anyone just jump on Evoscan and tell me what their Eval formula is supposed to be for 2byte load? Thanks in advance.
Ok, back to issues with this rom lol
stft around -12
ltft at 0.1
ive adjusted the biss using evoscan in sas mode and logging with zeitronix to get my rpm. at 850
my mods are;
hks test pipe and ex
rmr dp
rmr upper piping
dejon intake with perrin filter
gfb stealth bov
walbro 255
arp head studs
kelford 272 cams
zeitronix wdb
greddy profec b spec 2
ltft at 0.1
my mods are;
rmr dp
rmr upper piping
gfb stealth bov
walbro 255
arp head studs
kelford 272 cams
zeitronix wdb
stft around -12
ltft at 0.1
my mods are;
rmr dp
rmr upper piping
gfb stealth bov
walbro 255
arp head studs
kelford 272 cams
zeitronix wdb
ltft at 0.1
my mods are;
rmr dp
rmr upper piping
gfb stealth bov
walbro 255
arp head studs
kelford 272 cams
zeitronix wdb
First, I need the numbers for LTFT low and mid.
Also, if you STFT is at -12, your LTFTs are probably off.
No he is correct.
Or better yet, if you have your MUT table defined in your XML, tell me what the value is in 1C.
Your loads should be as follows (if it follows the same pattern as the other ROMs):
2-byte LOAD_Raw (no temp compensation)
hex value at 1C in MUT table + 0x09
hex value at 1C in MUT table + 0x0A
2-byte LOAD_Temp_Compensated
hex value at 1C in MUT table + 0x0B
hex value at 1C in MUT table + 0x0C
2-byte LOAD_Baro_Compensated
hex value at 1C in MUT table + 0x0D
hex value at 1C in MUT table + 0x0E
2-byte LOAD_Temp_and_Baro_Compensated
hex value at 1C in MUT table + 0x0F
hex value at 1C in MUT table + 0x10
I could probably tell you if I had the ROM. Where can I download it?
l2r99gst to the rescue.
l2r99gst, that 94960013 ROM is rare and sometimes has been said its not even an Mitsu OEM ROM, so I dont know where you could download it from.
