how does one find where things are in mut?
id like to know the steps involved in finding where things are.
more specifically 2 byte load in 9694013. im willing to do the work to find this info if someone can direct me in the right direction as far as how it is found
And really, you need to move to a more supported ROM. Or you'll be making these threads everyday.
Also, member "L2r99gst" also had that ROM in his car before moving to 9653. He may be able to help you out on addresses for that ROM.
well thank you but ive already tried using the numbers from 4011 and it didnt work.
as far as a more supported rom. and doing more work ,i spent the entire day and night working on 9653 v7 in my car and it still stalls at idle with the ac on. and the only reason i switched was to log 2 byte load. not a fair trade for crap idle i think . so i think its easier to make my stock rom log 2 byte load then play with this 9653 rom.
those are the only two i can use. 9417 is not available ive tried it.
ive had two different guys try to fix this idle and its a problem in the rom ,im not the only guy that has this issue. weve checked the maf scaling,stft and ltfts. and all the corrections in the world to the iscv dont do it. so im back to my stock rom and the car is running great again.
im not looking for a greatly supported rom, just one thing 2 byte load. im not trying to build some 700 hp cornfed monster. just the basics and a tune around 400 hp and im done with it.i built too many 600 hp cars and in the end i hated them and sold them
Use 9417. It IS available It WILL work. And it will work on a 05, I did the testing. I have told you this in a couple threads. If you need help getting it to work, PM me or email me, Jay@boostedtuning.com
You WILL want a supported ROM. You think you may just need 2byte load now, but I guarantee you will want to add something in the future and the 9694 ROM is NOT supported.
Or at least just use 96940011. Its much more supported then 96940013.
9417
i tried to download 9417 from evoecu and it was incomplete. stopped right after the isc tables no mut or anything. do you have a complete 9417 you could send me? email is adcgn45@aol.com
thanks
thanks
thanks
thanks
thanks
thanks
![Smilie](https://www.evolutionm.net/forums/images/smilies/smile.gif)
thank you i love how you chime in just enough to tell someone they are wrong,but dont actually say anything about a solution or offer anything up. but how can i blame you ? your in this for money.lol
Also, I responded to your emails and have been helping you, so I have no idea why you'd make a comment like the one you just did. Im not gonna spoon feed you every lil thing about tuning. Maybe you should read up more.
And I defiantly do NOT do this for the money. I do this for the passion.
To answer your current question, when downloading 9417 V7, there will be an .xml file aka definition file included. Place that file in your mitsu/evo definitions folder in the ECUFlash program files.
If you need more help, PM or email. (even though I shouldn't help you no more after you above comment)
sorry man not trying to talk badly dont take it the wrong way.
and i dont need everything spoon fed to me ,thank you.
you just mentioned the obvious which was that it was not defined and i knew that. i was looking for these definitions.
i asked if you had them so i wouldnt have to spend an hour sifting through crap to to get to them.
anyway i have a full 9417 v7 rom and i had nearly the same issues with ac on. it seems that when i get off the throttle it gets incredibly rich and i think this is what stalls the car. when i compared it to mt stock rom it didnt do this
i dont know what table to adjust to change this im guessing a decel fuel table but im not sure
If you'd like my help, you should be more polite.
