Torque seems low and late
#76
No it wouldn't be from a FMIC pressure drop because all that would do is lower your boost curve equally throughout the pull. It should still hit peak boost at the same RPM, it would just be less boost. What rpm do you see your boost peaking at in 3rd gear and what rpm are you seeing peak LOAD in your datalog in 3rd gear?
#77
Peak Load is around 3700rpm. You are right . It doesnt make sense !!
David Buschur
Apr 26, 2010 05:22 PM
David Buschur
Mar 6, 2009 07:30 AM
04AWDTURBOEVO
93
Feb 24, 2007 06:53 PM
