Looking for Bone Stock Map from an 05 RS
I picked up my car used, and I am not sure if the map has been flased or not. I would like a completly stock map so that I can compare and see if anything has been altered.
I tried to search but I must be special ed because I was unable to locate a map.
Also another thing this car has wrong with it is under full boost 1.2bar(~17psi) the cars ignition will break up really bad. If anyone has any suggestions I am open to them.
Use the 94170015 rom.. its the best rom. there is a forum with stock roms. I will dig for the stock ones on my pc and let you know if i can find them. make sure you keep your current rom safe tho u need the immobilizer code from it if you want to use that security feature (which i highly recommend) - it stops people from cloning your keys and stealing the car.
