Timing Map since i increased my Boost
The reason i want a dyno is because i think its going to take some time to sort the fuel map completely and i dont really like doing repeat 3rd gear pulls on the road, the road i go to is a long straight road, its an access road for the power station so i dont want people calling the cops while im there for more then half an hour
Nah i dont randomly change anything, i could get it in 1 pull, or it could take Half an hour to get right either way i dont like doing road pulls all the time, i need a license to get to work, so Dyno is prefered
6542111222233333333444455555555555555566777888889910991010101010101011111111111111111111
It doesnt ever jump more then 2 degrees
you could do with rescaling your map to make better use of "big maps" too.
sometimes i find if a register knock in a cell its not always that cell timing reduction that gets rid of it. its the cell before . normally the cell but sometimes
its just 1 o 2 counts of knock means nothing widge...
try to get afr leaner in spool up area , try to get 12.5 the best afr to heat the TURBINE and get a faster spool up.. if you desire faster spool up...
Yeh i know its nothing, im happy with it at the moment,
Yeh ive got to get back out there and sort out my fuel, it will also help with my IDC, there currently at 95% with the sort of rich tune,
Cheers guys
Cheers guys
