Timing Map since i increased my Boost
Hi All,
I have increased my boost to around 26psi, i have a map below and ive tried tracing the timing map when its on boost,
Im having a little issue where im getting some knock at around 6000rpm to redline, the timing map hasnt changed there from when i was on 23psi and i never got any knock there before, and i believe its the same cells too.
Its not knocking every pull maybe the first 2 and then the 3rd could go clean
Just want some input ill try get a log attached tonight.
98RON AUS, but i think thats about 93OCT in US,
AFR is around 10.9ish ill log tonight and post the log with my Wideband Plugged in.
The thing i cant work out is that before increasing the boost it was still hitting those cells at 6000+
Nah what i meant was because the boost is falling off by 6000rpm
Im logging Load 1byte with Tephra V7 which means i dont have to log 2byte,
Ill log the car tonight and post the logs for the pull.
But i dont think the timing map is very aggressive, opinion?
Yeh im gunna log it tonight but i mean the difference in timing between Max Torque, no knok and then where it knocks its not even that much more timing ill log tonight can only check after logging ill post then
Ok so its not knocking like i thought it was, im happy here are some screens of Knocksum and AFR using MAPTracer,
Ive also attached the Log too, note i did 6 back to back pulls this being the last, so this being the worst case scenario
Yeh i know the car is running richer then it should be, and nah the 2 logs before that the runs where clean with 0 knock all the way through, and my first log had 2 counts up top so no the knock isnt always there its random and not much anyway.
I really need to get the car on a dyno to sort the AFR's correctly, but where i live in AUS 4WD dynos, there is prob 1 within an hours drive
The reason i want a dyno is because i think its going to take some time to sort the fuel map completely and i dont really like doing repeat 3rd gear pulls on the road, the road i go to is a long straight road, its an access road for the power station so i dont want people calling the cops while im there for more then half an hour
That 2 count isnt there on the other 5 logs i have, as stated this is after 6 back to back pulls and this one had the most knock in it all others where clean
