Request for start log with the push of a dash button
yes please. and while you’re at it can you find out if there is a better way to log a Subaru... they have to have something similar to Mitsubishi’s mutIII protocol that can log faster than 4800 baud...
romraider is cool but the resolution is terrible iirc. You get something like 30 samples/second. The min/max values are great and so is the defrost as a start. This would be great for logging at the track when your netbook or laptop are secured down or hidden. I would make a direct request to hammish though.
I know i posted this same request like a year or so ago. I believe someone found the AC button is the only dash option the ECU logs. That would throw things off engine wise though. I would consider looking into adding a button if really desired and using an unused input or hijacking one. *paging JoT*
![Smilie](https://www.evolutionm.net/forums/images/smilies/smile.gif)
Also, for each parameter checked it shows a min. and max. value for however long Romraider has been running. Whether you were logging or not.
Meaning if you were driving around and didn't feel like scrolling through 5000 lines of log to see what the max knock your were getting. You can just look at the max value.
tunermt
12
Dec 13, 2023 04:12 AM
