Ecuflash Problem
Ecuflash Problem
I am having a probem with Ecuflash just closing down when scrolling up and down the ecu tables in the sidebar it only seems to happen with 88570008 and it does it when i use the compare ecu function on some roms
I am using all my defs that i normally use that were working fine with the last version i was on the version i am on now is 1.43.3150 is anyone else having the same problem ?
Try looking through this thread https://www.evolutionm.net/forums/ec...ne-else-2.html it mentions the 963 variant of but may be a solution to your or help you with your issues. I was having the same problems but not on the rom that you are using.
Yeah, that used to happen when I made the switch to the other betas:
https://www.evolutionm.net/forums/8797313-post1486.html
I'll send you my current XMLs when I get to my other laptop as I can't remember what edits I made as I tidied it all up aswell
