ECUFlash connection problems
Old Nov 23, 2010 | 09:33 PM
xmaciek82x's Avatar
So all of the sudden when I try to flash my car I get:
[22:21:24.234] sending init sequence 1 (0001)
[22:21:27.437] sending init sequence 1 (0003)
[22:21:30.656] sending init sequence 1 (FFFF)
[22:21:33.359] no response to any known code
[22:21:33.359] interface close
Anyone know why this started happening?
Old Nov 24, 2010 | 07:33 AM
hearnoevo's Avatar
battery
sounds like low battery voltage. Check your battery.
Old Nov 24, 2010 | 08:31 AM
xmaciek82x's Avatar
Its new (about 7 months) red top. We did get into the 20 degree weather for the last two days, and voltage is usually lower then, so maybe it can be battery voltage.
Old Nov 24, 2010 | 08:51 AM
wht95scort's Avatar
you should have the car on a battery charger while flashing
Old Nov 24, 2010 | 08:58 AM
kanyonkid's Avatar
or start your car and let it run for a few mins..
Old Nov 24, 2010 | 09:15 AM
hawaiian_evo's Avatar
One day I decided to flash my car the battery voltage was so low ecuflash wouldnt even see the tactrix cable. (I barely use my car) So i do believe that a good charged battery is needed. But like Kanyonkid said let it run for little while rebuild a good charge ... If that fails maybe reinstall ecu flash
Old Nov 24, 2010 | 11:19 AM
xmaciek82x's Avatar
Thanks guys. Will try later today. Kind of had a feeling it might be that since it logs fine.
Old Nov 24, 2010 | 11:30 AM
l2r99gst's Avatar
That would be my best guess as well. Just run the car for a few minutes first.
Old Nov 25, 2010 | 10:06 PM
xmaciek82x's Avatar
Yup. That's what it is. So I guess 20 degree weather and a relocated battery in the trunk causes some greater voltage drop. Never before had this issue in spring or summer.
Old Nov 16, 2011 | 08:20 PM
wcassar's Avatar
I have some related problem, the error is open port 1.3 Jetc etc
and then connection closed
what can cause this?
I have already read using evoscan i.e the reflashing cable is working fine
5LEEPERISAH23I
Dec 3, 2014 09:40 AM
jaekaelae
Dec 1, 2012 07:01 PM
Hollywood_Evo
Nov 8, 2011 07:22 AM
SSS
Feb 18, 2010 06:08 AM
