Stop your Car Stalling from Clutch in!
The solution for this issue is posted here Post number 53/54:
https://www.evolutionm.net/forums/ec...ng-issues.html
That doesn't work for me either because my load increases when the idle stumbles:
Longer log attached.
have you adjusted the biss screw? I had the same problem you had with my old 9 and I believe it was because of the cams.my friend had the same problem too and he had m2 also.i had to set my biss and idle up to get rid of the issue.it still came every once in a blue moon but I could not replicate it.
My friend tried putting back the stock intake too and the stalling still happened. It seems the post I linked should solve your problem...
What are your fuel trims? It looks like you are running very rich...
Yep, idle is set to 1k.
When it stumbles it goes very rich. Oddly enough, when I was in closed loop, when it stumbled it would go full lean, and now that I'm in open loop, it goes full rich.
Trims should be fine, they're within +/- 5%. Still on stock injectors.
How do you know if its set properly?
Same here
My log look just like yours 400-500rpm with 90s load and 5 degrees timing
Wizzo, to check the BISS, activate the Speed adjusting screw actuator in evoscan. This will lock the IAC at a given position and allow you to adjust the BISS to the correct idle speed. Turn the BISS counter-clockwise to increase the idle rpm, and vice versa.
That being said, I've had quite a big breakthrough this week regarding my idle problems. I had checked the BISS a number of times and it was idling at 1k rpm, which is the same as what I have set in the rom. I had opened up the BISS some more to try to combat the drop to 500rpm, but it wasn't helping. Then it hit me - before my rpm's drop to 500, they would surge to 1500. So I wondered if the BISS was getting the idle to 1500 because it was opened too much and then the ECU over-compensated with the IAC and brought the idle down to 500. So I started gradually closing the BISS, without activated the actuator, so that the ECU would adjust the IAC to keep the idle at 1k as the BISS was closed. I would close it around half a turn and try it out on a drive. Each time I closed it some more, the idle would surge less, and it would subsequently drop less. I've now got it to where it surges to 1100 and drops to around 900, then goes back up to 1000, which is much better than before. I'm still tweaking it, but it definitely seems like I'm the right path.
However, sometimes when I clutch in at low loads going uphill it will still drop to 500, however it recovers much quickly. I believe this may be a separate problem. Either way, it's still vastly improved compared to what it was before.
Now, if your idle doesn't surge to 1500 before dropping to 500, I would NOT try my trick of closing the BISS. I don't think it would work, and it may instead make it worse, as the IAC and BISS will be working against each other.
uneekvisions (Jan 26, 2023)
Ok I checked my biss with Evoscan and it was low. About 800rpm. My desired idle is set to 960 so I set the biss to 960. I'm assuming that is correct. If it is I was wondering if I set the biss higher than my desired idle will it idle at the biss setting or the desired set idle. I didn't have much time to play around with it so I didn't get time to test this. The reason I'm wondering is because now my idle is at 1100 rpm. So for now I dropped my steps at idle in the 170 and 180F cells. Now its idling at 960rpm. Not sure if that's the correct way to fix it but its works for now. My clutch in is a little better but is still trying to stall with clutch in after light load like when parking or stuck in traffic.
