Tial BOV opens/ stutters while on boost
MY Tial BOV (QR) opens and stutters while on boost (before lifting throttle). The car is running V7 SD and I have noticed that playing with the MAP/VE/RPM table effects it, although I have not been able to fix it.
Is this purely a function of the spring in the BOV or is it related to my load and pressure settings for SD?
Any help or previous experience appreciated
![Smilie](https://www.evolutionm.net/forums/images/smilies/smile.gif)
I consistantly log -7/-8 PSIg at idle and I specified an "8" PSI spring when I ordered from Tial...
However I also specified silver and they sent me a red one so I guess that could also be a question.
I can hear the piston stuttering in the BOV and looking at my logged boost and WGDC I think I can rule out surge.
It seems to be sensitive to getting the load/pressure correct on my SD settings. My setting look a little different than the tuners that know thier SD so I'll start there.
Does anyone know if springs are interchangeable between the 50mm to the QR?
Thanks guys!
Thanks guys!
I vote the spring is too stiff, drivability is directly affected by the bov being adj. correctly. I lucked out with a APS twin vent and when the spring is too stiff, there is part throttle flutter and abrupt blow off under heavy throttle light lift-off
Yeah... I was initially annoyed by his post mostly due to the "search" comment, but after lowering WGDC in the problem areas it went away, so I guess I stand corrected. FORSAKEN's post was more helpful
![Beer](https://www.evolutionm.net/forums/images/smilies/beer05.gif)
Throttle lift-off also makes a similar messy stutter instead of blowing off cleanly, this may be too (soft?) a spring?
**edit** saw post above, perhaps I should try an even soffter spring? Someone had good results on a 3 psi spring above...
I'm too stupid to figure out boost error correction LOL. I 'm currently just using gear dependant WGDC like an EBC with everything else 0'd out. I think that will be my next venture once I get my SD tune nailed down. but yea that seems to be it.
ECU controlled boost or a larger turbo I think are about the only ways to completely cure compressor surge, which I battle constantly due to my EBC/stock turbo. I build 24lbs of boost at half throttle @ 3500-4000rpm if I'm not careful how I accelerate. Drives me crazy.
Larger turbo wont build as much boost at part throttle, and ECU controlled boost will allow you to tune your boost curve according to throttle/load, so you can set it to build only 5-10lbs at normal driving, then full boost whenever you need it. This will be my next step....if the BT doesn't come first
![Stick Out Tongue](https://www.evolutionm.net/forums/images/smilies/tongue.gif)
