Need help logging AFR
I have problem with logging AFR.
1 .I have zetronix ZT3 wideband
2. Evoscan, ECU flash and all cable to connect and working on the computer
If anyone can help me
I try to log AFR by Zetronix ZT3 and I dont know how to make it works with Evoscan?
I can display AFR But Its separate from Evoscan Excel sheet and Thats make me dont know what RPM, Load and Boost and etc.
I thought It should works on Evoscan
I just need to know how to set up
I actually need to know how to set up ZT3 to works and display on Evoscan which I can see everything on excel sheet and compare RPM, Load, Boost, AFR Fuel map and Timing map
any input ? Thanks in advance
not actually sure if its compatible, but lets say that u could use the ZT-2 as ur WB. Did u click on (under WB on top of screen) ZT-2? Did u set the COM port? While the cable is connected to the ecu, (ignition on) open up evoscan, click on the WB button on the top of the screen, open up windows device manager, and find which COM port its on, and then set the COM port in evoscan to match. Then make sure that u check the WB data item to be logged, and should be good 2 go...
GL
GL
GL
GL
Need some help !
GL
GL
TTP Engineering
Evo 'For Sale' Interior Styling
141
Jun 3, 2010 10:21 AM
TTP Engineering
56
Dec 27, 2006 10:17 AM
