what load is LTFT Low?
Fuel trims are Hz ranges, not load. There is a table in the ECU (if you have it defined) that sets what ranges the change from Low to Mid and Mid to High occurs. I have it labeled as 'Closed Loop - LT Trim Control'.
For 9653, the defaults are Low-->Mid: 75 Hz and Mid --> Low: 62.5 Hz
What that means is when you're idling anything below 75 Hz will be LTFT Low. Once you cross 75 Hz, you need to fall back under 62.5Hz before LTFT Low becomes active again.
^ What he said. here's what you need to add to your xml to be able to see the tables in EcuFlash for 88590015:
<scaling name="LT Trim Hz" units="Hz" toexpr="x*6.29" frexpr="x/6.29" format="%.0f" min="0" max="1610" inc="6.29" storagetype="uint8" endian="big"/>
<table name="Closed Loop - LT Trim Control Ranges" category="Advanced Fuel Control" address="3021" type="2D" level="1" scaling="LT Trim Hz">
<table name="Conditions" type="Static Y Axis" elements="4">
<data>Low -> Mid</data>
<data>Mid -> Low</data>
<data>Mid -> High</data>
<data>High -> Mid</data>
</table>
</table>
</table>
</table>
