Computer/Evoscan/Stupidity Problem
Background: Running Windows7 Pro 64bit, 1.3 Tactrix, 06 Evo IX, tephramods (did put tephramods file into the new Evoscan rommetadata folder)
Recently, I reformatted my computer and wiped everything.
Reinstalled evoscan (2.7 and 2.8) and ecuflash, but I can't write to my ECU. Uninstalled and reinstalled and same result.
I figured it was the drivers, but when I went into the Evoscan folder (in Program Files (x86)) and attempted to us DPInst, it did not work, saying I need to run 64 bit. I tried running Evoscan connected, and a similar message popped up about installing drivers. Any ideas?
Thanks
Thanks
can you connect to the ecu at all?
I had a similar problem a couple nights ago. I couldnt get ecuflash to connect at all. i kept getting a blank pop up box on my screen with no details. I tried for about 40 mins with different plugging in procedures. when i fired up evoscan, rechecked all connections again, i was able to hook into the ecu. once the connection in evoscan was made, ecuflash connected with no issues.
If you have evoscan try loading that first. you also may want to run the free ecu unlocker thats out there. i think its just called "ecu unlocker"
thanks for the response - i've been tuning and etc and stuff before, i'm fairly certain it's strictly a driver problem.. i think i was supposed to partition some of my hardrive to run 32 bit or something like that and i didnt.. or something
but i'm thinking it must work for people who are running 64 bit computers.. just need to know how i can install the drivers in evoscan.. cuz installing ecuflash alone and evoscan alone doesnt work
Thanks
Thanks
Did you install ecuflash with the tactrix cable connected to the usb port? if not, you must do so because ecuflash will attempt to read a code from the tactrix cable confirming its legitimacy for usage.. its there way of keeping track of their own hardware design vs others and keeping customers locked onto only using their cables with their software.
Is the 1.3 a 1.3R or a 1.3U? the 1.3R can only read in evoscan, but the 1.3U has a tactrix license built into it and can read direct from the ecuflash software.
well as you know the 64bit platform is cross compatible with 32bit. so if you're on a 64bit OS you can run 32bit applications.. but when on 32bit OS, you cant run 64bit.
I'm not sure which version of the tactrix cable it is unfortunately - but I do know that it worked for everything before - ecuflash, evoscan, logs, uploading/downloading ecu maps etc - the only thing that has changed is that i went from windows7 64bit HOME to windows7 64 bit PRO, and erased all my data/drivers in the process.
Thanks for the tip, I'll update tonight to see if this works.
Ah gotcha - I will try reinstalling ecuflash with the tactrix cable IN the usb port - will I also need to have the tactrix cable plugged in the car?
did you try communicating with the car via evoscan flashing? by default ecuflash is installed in the x86 program files folder on the OS which represents its a 32bit application. all 64bit apps go into the regular program files folder by default.
example C:\Program Files (x86)\OpenECU\EcuFlash
no not plugged into the car, just the laptop or computer so it can read off the usb port.
Actually, before the error from evoscan was that I didn't have the drivers or something and tried to link me to the website. Not sure why that changed.
Should I go ahead and reinstall ecuflash with the tactrix cable in?
Oddly, evoscan is still not reading the USB?? (same message as second image above, usb cable not responding, unplug and retry)
What to make of this? Thanks for all the help
