Trouble setting up Tephra v7 (94170715)
Hey guys,
I tried to setup v7 tonight on my car. I made sure to transfer all relevant values to the v7 rom (timing/fuel - both stock, immobilizer, etc.) and went through as much as I could to make sure it would be fine. Then I loaded it up and started the car. The idle was really unhappy though. It kept going from 2k to 2.3k and back down, and then down to 1.4k, back up, etc. Really weird. I haven't tried the suggestions on the "poor cold idle" thread yet (main one I guess is battery disconnect) because I've been more worried about the evoscan log.
This is the v7 log. As you can see no parameter (except external wb02) appears to be correct. Even the speedo! Apparently I went 0 to 308mph in less than a second . This is the log when I reflashed right back to my stock ecu rom. What am I doing wrong?
Also where can I set baud rate in v7? I couldn't find the sub section in ecuflash (yes I'm using the right xml). Maybe its because I have the baud rate set at 62500 on evoscan?
Yeah I have the 941 just as a reference but Ive been using the 965 for so long it seems like to much work to move to the other rom. Also for the lean start I found that the maf comp vs coolant temp helps a bit for that. Thats what I did when i was still on maf and it worked fine for me.
My problem isn't on start up though. Its when the engine is warm and I push in the clutch (put the car in neutral). The revs drop way too low and almost stall. Then it idles at like 550ish rpm when its supposed to have a target idle of 852. And the idle is really fragile. Any suggestions on which table to modify?
Btw this is all on phenem's pre modded rom. Not the base v7.
https://spreadsheets.google.com/ccc?...3g&hl=en#gid=0
^ that shows one of my logs from the v7 965 rom. Its option 4 with the EGR, EVAP, and idle tests disabled. Not sure if thats significant. Look from row 487 down. I did a pull and then let of the gas, the car sinks as low as 500rpms and almost dies. But it stays very low in rpms even after that. Column AE is my wideband btw. And this happens not just after a full throttle pull, it happens even after cruising around.
The Idle Stepper Lookup Table is identical to my stock rom. Values start at 0 from 0 load and go to 136 on 162kpa load. Would I need to readjust the idle screw even if it was never touched and ran fine on the stock rom?
It has an idle error table which defines the maximum number of iscv steps the car will add to keep it running at idle. There is also a desired iscv position which is like the base of the idle.
I see. So do you think I should modify the desired ISCV first or the idle error table? The 965 rom doesn't really show anything strictly called "Idle error table" but I assume the ISCV demand adder #1 is the table I should be looking at. I remember reading on a search I did on the issue that referred to the demand adder table. That was for cold start idle but I assume same thing applies for the warmer temperature values in that table.
I think when it warmed up the car was pretty much staying alive using the ISCV demand idle recovery adder, which activates at 500rpm. Which is the point around which it was idling. So I'm inclined to think its an ISCV related issue.
Maybe you should try download his xml's if the tables aren't defined for you its in post 2 of the tephra thread.
