a few little V7 launch map questions
Hey guys,
just converted the car to V7, having a blast testing out the features!
few questions about the launch maps....
if i leave the map TPS setting at 40%, does that mean i've got to hold the pedal at that point for this to work?
also, i need to set the TPS setting / stat rev limit so that they dont interfere with one another, correct?
thanks!
thanks!
Setting the TPS at 40% means once your TPS passes 40% your launch map will be activated.
I'm not sure what you mean by your TPS setting interfering with your 2-step. Say you set the TPS threshold for launch maps to 60%. If you give it 50% throttle, you'll still reach your 2-step RPM (say 5k), but you won't be on launch maps. If you give more than 60% throttle, it'll switch to your launch map but it'll still hold at your 2-step rpm.
WTB[Northeast]: Need an Evo 8 TPS and MAP sensor
turboedv6
Aug 29, 2015 06:37 AM
