issues with my ecuflash...
Old Mar 23, 2011, 04:36 AM
burgers22's Avatar
Originally Posted by burgers22
Looks like the read_evo xml is in a different folder to the one you have specified in the amls folder options. The read xmls are in a read templates folder which is usually in C:\Program Files \OpenECU\EcuFlash\rommetadata or C:\Program Files (x86)\OpenECU\EcuFlash\rommetadata for Win 7. You need that folder and it's contents copied to the path for the rest of your xmls.
I would still say you don't have the read_evo folder in the same path as your other xmls folders. ECUflash can't find the read templates.
looking at your screen shot the ROM metatdata is in the c:\users......roaming\ path, the read_evo folder and it's contents need to be there as well
Old Mar 23, 2011, 06:30 AM
Stradag's Avatar
I also have this problem, luckly I use tephra V7 and i have back up copies in my laptop already.
I am using windows vista
My car is a 2003 EVO gsr
ROM ID: 94170715 using APPLAUDS V7 XML
I tried uninstalling and reinstalling ecuflash and evoscan
I am using ECUflash 1.42.2595
I am using the Tactrix 1.3U cable
I can not read my rom.
Ecuflash comes up with a blank screen when trying to read (shows no selections).
I can not read DTC codes with Evoscan.
I can read and write Evo IX roms.
My read template file has
read_evo5.xml
read_evo7.xml
read_evo9.xml
read_evo65.xml
etc...
OPTIONS > Metadata Directory in ecuflash is:
C:/Program files/OPENECU/ECUFLASH/ROMMETADATA/MITSUBISHI/EVO
My battery is in A++ condition, 12V or over when writing to ecu or trying to read
I can write roms no problem at all.
I can scan OBD codes with Scan Tech and the tactrix 1.3U cable
I can log with EvoScan
I have been able to read my rom and read DTCs in the past, unfotunatly IDK the exact time this started happening. Hopefully we can fix this.
Mabye a problem with vista? I know vista can be a pain in the **** lol
Old Mar 23, 2011, 06:57 PM
DREVO978's Avatar
i got windoows 7.. i tried copying the templates ova and still nothing.. i uninstalled everything of my laptop and reinstalled and still the same.. evoscan connects and logs fine... its just ecu flash.. my battey is good.. reading more than 12v..we need to find a solution asap.. sumone.. please help us lost ones lol..
Old Mar 24, 2011, 12:05 AM
burgers22's Avatar
1. What happens when you do a fresh install and leave everything as standard, don't change any paths etc?
2. Do you copy the folder, or just the templates?
Old Mar 24, 2011, 05:49 AM
Stradag's Avatar
Dr.evo your meta data directory is not pointing to the correct folder, it tells you that on the log screen of ecuflash in your picture you posted
Old Mar 24, 2011, 02:35 PM
DREVO978's Avatar
it does the same even if i delete everything and reinstall it.. ive even tryied different versions of them and still the same..
i did all the templates in that folder..
Old Mar 24, 2011, 02:36 PM
DREVO978's Avatar
how can i go about fixing this... i mean i figured by deleting the entire thing and reinstalling it.. it would of fixed it self.. but i guess not..
Old Mar 24, 2011, 02:40 PM
DREVO978's Avatar
i was looking at how it says the ecuflash does not exist on the 6th line.. is that the issue maibe.. not finding the proper documents needed to read of my ecu..
Old Mar 24, 2011, 02:43 PM
Stradag's Avatar
You need to direct it to the correct folder, when ecuflash is open go to file then options then metadata directory. Hit the browse button and select the folder that you read template folder is in.
Old Mar 24, 2011, 04:54 PM
burgers22's Avatar
I'm wondering if you need to delete the registry entries for ECUflash once you've uninstalled it. BTW do you run it as admin?
Old Mar 24, 2011, 05:07 PM
DREVO978's Avatar
yea i think it is.. cause doesnt it have to be as admin. in order to put in a patch?...
Old Mar 24, 2011, 05:09 PM
DREVO978's Avatar
ok so i went to the options and to the metadatadirectory and it said rommetadata on the selection.. and i went through and put it in the read template.. i think wen i was trying to do the tephra i might of changed it by accident.. but now wat is the rom file directory suppose to be set at?.. cause i did that one by accident.. i thnk i put it back to wat it was but just wana make sure..
Old Mar 25, 2011, 12:29 AM
burgers22's Avatar
As I've said, you need to do the folder.
Old Mar 27, 2011, 11:22 AM
DREVO978's Avatar
problem is fixed.. i wana thank all that helped me.. but especially stradag.. lol.. i let him connect to my pc and he worked his magic.. not sure wat he did.. but he did it lmao.. thanks a million..
ReignMan24
17
Aug 27, 2013 10:40 AM
dinok
25
Apr 5, 2011 08:36 AM
bLiTzD
59
Jul 23, 2010 09:19 PM
Buksh
Aug 1, 2007 01:22 AM
bvdawg13
20
Jun 14, 2007 07:26 PM
Quick Reply: issues with my ecuflash...
