90 load in evoscan?
90 load in evoscan?
I have a 05 evo and have recently started the tuning fun. I have 3in turbo back exhaust and an cobb cone filter. The car was cutting out due to overboost. The last "tuner" that had the car had the wgdc at 100% across the entire rpm range. Why would a someone do that?I lowered the boost down to 10psi by adjusting the wgdc tables and now my 2 byte load is only logging up to 90 load . Is this a normal load cell figure for peak 13psi holding 10psi to redline?
My understanding is that if Im in boost I should be logging load greater than 100.
Thanks for the reply.
I checked my addresses like 10 times thinking the same thing.My best guess is something got copied to the rom file incorrectly. I'm going to re-download evoscan and load tephra V7. I'll log one byte load from there and hopefully everything will pan out.
