ix SD fic 2150's base map needed
i was just hopeing to get a map to fire it up and let it idle check for leaks and what not.
aarron wont be back til wednesday, i guess i'll wait a day or two more. thanks it was a long shot.
download the rom from tephra v7 thread for your rom id and SD .. the roms are already setup for it and will use the fuel temp as IAT by default.. then set the injector scaling to 1329 for e85 or around 1700 for 93oct.
it will run without any tuning as long as the injector scaling & latency are set and the map sensor scaled properly in the MAP ve calibration table..
the roms on the thread are already 80% setup so u can flash and fire the car up after scaling injectors..
thanks for the help, i got the map now as far as the scaleing/latency
1720
3.72
2.088
1.44
1.08
0.84
0.672
0.552
This is what was on the map, i just changed the scaling to 1720. hope this works.
1720
3.72
2.088
1.44
1.08
0.84
0.672
0.552
it will be like stock.. its like stock on my car on gutted maf.. i have my car idle so smooth you cant even tell my car has cams in it.
these injectors kick ***.. they are great.. but if you run them on pump gas 91-92-93oct etc.. you should patch your rom with the IPW minimum code by tephra so you can control them and your afr better. on E85 it will not need done though.
2150cc fic are identical to id2000, except id2000 go through more thorough testing before sold. with that said i recommend the fic price for price.
they are both Bosch injectors and share the same spray pattern.
WTB[MidWest]: WTB FIC 2150's
STLEVOIX
Aug 26, 2016 07:10 PM
WTB[MidWest]: FIC 2150's
2bar_evo
Jun 26, 2016 11:28 PM
FS[SouthEast]: FIC 2150's - $600
MacMan
Nov 19, 2014 04:23 AM
