OMNI 3-bar MAP sensor scalings
I know this tread is old but i cant find that map scaling map in my TephraMod V7 rom
do i have to add it ?? i just ordered omni 3bar map sensor and i dont know what to do next
pls help guys
thnks a lot
pls help guys
thnks a lot
You may have to add the table defs to your xml. You should be able to find them here:
https://www.evolutionm.net/forums/ec...tructions.html
1)
Why is this scaling not quite linear? How come it isn't:
24 (vs. 25)
48 (vs. 49)
72 (vs. 70)
96
120
144
168 (vs. 170)
192 (vs. 195)
2)
For EvoScan logging, I am adding a new item with that formula. I noticed there is already an Omni 4Bar item in my Tephra v7 XML, and it has a slightly different formula than yours (aside from the 4bar scale).
From this post, the 3Bar formula is: * x + 0.161 - y
In the Tephra XML, the 4Bar is: * x - y
What is the purpose of adding 0.161 to x for the 3bar sensor, and/or why does the 4bar item in Tephra XML not add 0.161?
Thanks!
Two questions:
1)
24 (vs. 25)
48 (vs. 49)
72 (vs. 70)
96
120
144
168 (vs. 170)
192 (vs. 195)
2)
Thanks!
1)
24 (vs. 25)
48 (vs. 49)
72 (vs. 70)
96
120
144
168 (vs. 170)
192 (vs. 195)
2)
Thanks!
Concerning 2), I just wrote it like that to make it easier to start at what should be your local atmoshperic pressure and adjust from there. I could have written this instead, which leads to the same formula but is a bit more complicated to explain:
And here is the correct Evoscan equation: 0.17886 * x + y
where y = 0.161 - your local atmospheric pressure (14.7 at sea level)
Regarding 1), frankly I don't know. I don't even remember how I got to the scaling I have now. I can check the logged values for my 3bar compared to my zeitronix sensor's reading to see if they match up perfectly, but I imagine I would have done that as well when I settled on those scalings. I suspect that changing them for the linear values you propose wouldn't change the logged value very much since they seem to be pretty close.
I bought this sensor to use with the Grimspeed boost controller, FWIW, but I don't want to even try MAP-based boost control until the Omni 3bar is calibrated properly.
