Another Idling Issue
Old May 5, 2011 | 04:20 PM
golruss's Avatar
Originally Posted by Lmodel
I havent encountered this problem before on similar setup.
To report back, I've set the FPR to 43.5 with vacuum off but it doesnt help..
Sorry if I come off sounding like a dick but you need to understand how a MAF based system works. The maf measures the amount of air entering the engine and tells the ECU which calculates the amount of fuel necessary along with some other parameters. Go Speed Density if you want to run VTA. Hope this helps.
Old May 5, 2011 | 06:42 PM
Lmodel's Avatar
No worries and I certainly appreciate all comments and inputs.
My only concern is I'm on VTA for the past 4 years and have not encountered this problem before. I can try to buy a recirculation BOV but worried this may not be the cause.
It seems like many people are also dealing with idling issues one way or another. I'd hope to understand what are the symptoms for each and every problem that are associated to idling. This way, I can do a compilation and create a new thread to help those who has got idling problems and help them identify their most possible problem.
Some of the those that I can think of:
1. dirty/ faulty MAF
2. dirty throttle body
3. VTA BOV
4. Faulty Idling Valve
5. fouled plugs - Symptoms include continuous rich/lean AFR during idling and sluggish power during drive.
6. Vacuum leak
Old May 5, 2011 | 06:52 PM
golruss's Avatar
3. VTA BOV
6. Vacuum leak
Ok no prob. everyone I know who have tried to run VTA on a MAF setup has your symtoms including my self for the reasons I and others have tried to explain above. What type of VTA are u using? Just realized it a HKS. You could also try blocking it off and see how it idles. Could u post up a log of a 5min idle?
Old May 5, 2011 | 08:06 PM
Lmodel's Avatar
I'll try to post a log as soon as I can. I couldn't explain why I wasn't experiencing this problem before but only after I change my injectors and cams.
What are the symptoms you experienced when you are on a VTA on MAF setup back then?
For me and when on closed loop:
1. Car starts alright on cold start and idle well.
2. After warm up, car goes close to stalling whenever i go into neutral.
3. During idling, car goes lean (down to AFR 19.0) and rich (up to AFR 9.6) and make no attempt to stabilize
When on open loop:
2. After warm up, car goes close to stalling whenever I go into neutral.
3. During idling, car goes rich only (up to AFR 10.0) but stables itself after a minute or two of idling and hovering between AFR 14.0 to 16.0.
Old May 6, 2011 | 01:35 AM
3K's Avatar
3K
Along with all the problems you described are you also getting the p0300 code continously?
Old May 6, 2011 | 03:00 AM
Lmodel's Avatar
Nope, no error code at all.
problem03lancer
Lancer Troubleshooting
Apr 1, 2017 05:45 PM
turbotaloon95
Sep 19, 2016 09:22 AM
Femi
AEM EMS
23
Apr 5, 2016 11:38 AM
LeXcite
Dec 5, 2015 02:33 AM
Appauldd
Sep 21, 2015 08:39 AM
Quick Reply: Another Idling Issue
