evo 7 ecu with 96532706
Old Apr 30, 2011, 08:21 PM
MRGEVO's Avatar
Hi guys,
I am running an evo 7 ecu with the 96532706 tephra rom patched by ziad. I am wanting to know if I can use Ecu based boost control using mrfred's guide found here:
https://www.evolutionm.net/forums/ec...t-control.html
Seeing as the 96532706 rom is for an evo 8, does this mean that I can just copy and paste the xml code required to run ecu based boost control? Or will the definitions be slightly off because it has been patched to run on an evo 7 ecu?
Any help would be appreciated, thanks in advance.
Martin.
Old Apr 30, 2011, 10:11 PM
philr8's Avatar
Why not donate to Tephra and run 90550001 V7, alot less hassles and will run correctly
96532706 is not meant for Evo 7 and seems to be hit and miss as to running correctly
Old May 1, 2011, 01:16 AM
MRGEVO's Avatar
96532706 patched for the evo 7 ecu by ziad seems to be working fine on my car, my guess is whoever has had trouble with it didnt scale their injectors and latencies and/or MAF accordingly.
I will look at that option soon, I am also trying to set up ecu based boost control and I am not sure if you can do that on 90550001. Thanks
Old May 1, 2011, 02:24 AM
RoadSpike's Avatar
To answer your questions yes the patch by MrFred will work.
You'll be able to use any of the patches for the 9653 rom issued since your using an evo 8 rom.
Old May 1, 2011, 03:47 AM
MRGEVO's Avatar
Awesome, thank you for confirming that. Cheers.
Old May 2, 2011, 03:29 AM
VGergo's Avatar
90550001 v7 can the psi based boost control idepenedtly for every gear as the v7 9653 ?
Old May 3, 2011, 02:54 AM
burgers22's Avatar
Has someone actually inserted the code in 90550001 v7 for PSI based boost control? 9653 already has all the tables in it to run this, you only need to change the values where indicated in ECUflash.
90550001 v7 had load based gear dependent boost control, though you may have to change the RPM/gear ratios if your ECU has been converted to be used in MPH. KPH should be fine.
richardjh
Aug 24, 2022 10:50 PM
kaya
Sep 21, 2014 06:42 AM
Mr_G
Mar 2, 2012 07:49 AM
Andy_8
Feb 12, 2011 12:34 AM
AlexEvo6
Jul 30, 2010 06:56 AM
Quick Reply: evo 7 ecu with 96532706
