NLTS for 96260009 TephraMod on 3 plug ECU's
Old Jul 26, 2011 | 04:05 AM
HyperDisorder's Avatar
Ahh, starting to understand a very little bit about reading code, cheers.
I'll get on to testing other pins as soon as possible, but it's too cold at night (I might just need to harden up), and this weekend's a write-off. Just in case anyone feels the urge to spend some time at it - I used the attached file (rename to .xml) in evoscan to find pin 88. Only have a few MUT table addresses ticked at once if you give it a go.
File Type: txt
Old Aug 1, 2011 | 03:55 AM
Guess who has NLTS working on 96260709?
I did what I earlier said I wouldn't attempt, and edited a couple of words to make it work on pin 88. Thanks d1kid for pointing out the routine for NLTS.
I edited the word at 3E318 from CB01 to CB02, and changed the memory location defined at 3E644 from 88CA to 8895.
This of course means that I can no longer use the auto ICS button to change to and from Alt Maps. I'll wire up pin 64 and see if that works, otherwise this is bit of a temporary fix.
Oh yeah BTW, NLTS is awesome! Smoother gear changes, instantly back on boost, and significantly less time to change gears.
Old Aug 5, 2011 | 02:03 AM
Just realised that my info on getting NLTS working was a bit incomplete, to say the least, so for those interested:
<table name="Set to D0D0 for NTLS. Originally D0CB" category="TephraMod-V7" address="3E314" type="1D" level="1" scaling="Hex16"/>
<table name="Set to C802 for NTLS. Originally C801" category="TephraMod-V7" address="3E318" type="1D" level="1" scaling="Hex16"/>
<table name="Set to E000 for NTLS. Originally D092" category="TephraMod-V7" address="3E40E" type="1D" level="1" scaling="Hex16"/>
<table name="Set to 8895 for NTLS. Originally 8950" category="TephraMod-V7" address="3E65A" type="1D" level="1" scaling="Hex16"/>
Just paste the two lines into your 96260709.xml change the values as described, and you're away!
If the original values are not C801 and 88CA, please let me know, and don't try changing the values!
These changes will still stop the Auto-ICS button from enabling the Alt-Maps feature.
Enjoy!
Last edited by HyperDisorder; Jul 5, 2023 at 05:19 PM. Reason: Forgot to add full final code and don't want to bump a 2011 thread into 2023.
scientist (Aug 10, 2024)
Old Dec 25, 2011 | 02:16 AM
Prolifik's Avatar
my internal ROM id says
96260009 & 96260012 Tephra v5.1
my tuner set it all up for me but i learn fast and been reading alot...
What do i need to do, to get NLTS to work on my JDM 8MR?
Old Feb 14, 2017 | 04:59 PM
eazlan's Avatar
96260009 & 96260012 Tephra v5.1 fro Evo 8 JDM, is there come out Speed Density version ( MAP Sensor ) of this ID ? mind to share.
C G
Aug 11, 2021 03:04 AM
reil_neil
Jun 10, 2015 04:31 PM
el.guerrero
Nov 3, 2012 04:25 AM
NeoGearX
Jul 13, 2009 04:55 AM
JoeBee
Sep 8, 2008 09:29 AM
Quick Reply: NLTS for 96260009 TephraMod on 3 plug ECU's
